Old 11-25-2021, 09:10 AM
Default Installing Garmin Transducer
Going for a little Black Friday goodies and on the list is a Garmin UHD 94 sv
Question is how best to run the transducer cable to the console?
I ques the choices are over the transom or drill hole thru it
Suggestions and pitfalls????
Old 11-25-2021, 10:58 PM
erebus erebus is offline
I put a Garmin 74SV on my Sceptre last summer, skipped the transom mount and went with a thru-hull transducer instead.
Not a fan of the transom mounts. Seen too many ruined transoms, and too many transducers flopping around and broken off at the ramp.
If you do go transom mount you can go through the transom just close out the core with epoxy where the wire goes through.
Zachary
Old 11-29-2021, 06:15 PM
caper caper is offline
Up and over through the rigging hose and to the console through the rigging conduit
Old 11-30-2021, 01:24 AM
nestorpr nestorpr is offline
I went over the transom and then thru a clamshell type cover that I completely filled with sealant to prevent water from coming in thru it.
Boatless again!
Old 11-30-2021, 09:22 AM
I installed it by drilling thru the hull, mine is composite, but used lots of sealant on bother sides so no water comes in.
Got the boat up to 45 and it still read the bottom, quess I placed it right.
Old 12-04-2021, 12:53 PM
I think I need to find tune the engine height up one hole. Wide open I could only get 4900 rpm trimer up. It does go close to 45 mph . Maybe try a different prop also.
Old 12-05-2021, 02:49 AM
¡Tienes el pelo blanco como yo!
Boatless again!
