Old 04-01-2013, 02:33 PM
bigeasy1 bigeasy1 is offline
I run a T8 8hp yamaha kicker on my boat,and it sits for fairly long periods with no use.It pulls the fuel uphill thru two 10 micronfilters.
I have two water separator filters,one 10 micron the the tank outlet,and another at the main engine(I/O).
I have the fuel line for the kicker connected to the spare output port on the second filter.I have the fuel primer bulb about a foot from the kickers fuel connection.
We troll for hours on end with no problem,the kicker pulls the fuel with no problem.I also run Startron as a rule whenever I put gas in the tank.Not sure if it really works,but so far after 4 years,(knock on wood,hope I'm not jinxing myself)I haven't had any carb issues.
All this,just for a boat ride
Old 04-03-2013, 08:21 AM
Originally Posted by mnwnvc View Post
I have had problems with other small engines when the fuel hoses on the engine start to break down. Find a lot of small black particles in carb and float chamber.
Thanks guys...I will change hoses and then add the filter to the transom and that should do the trick..
Old 04-03-2013, 09:40 AM
Abe's Rocket Abe's Rocket is offline
I run a Yamaha 15hp 2 stroke w/ a racor and have never had a problem.
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 04-06-2013, 11:26 PM
Hooligan Hooligan is offline
Default Yes on filter...
All of the charter companies in the BVI (and presumably elsewhere) run a small filter on all of their dinghies/ outboards so I would say no problem on pulling through a filter. I was amazed that all dinghies I have seen (been there on a few different occasions) are equipped with them. Must speak to the quality of fuel they get...
They are all transom mounted water separator types. Most of the motors down there seem to be 8, 9.9 and 15 hp yamaha 2 strokes.
I wouldn't hesitate to run one on my own 8hp yamaha. Ive got a '99 8hp two stroke on my 9' Boston Whaler and it gets around darn good and always starts on the first pull...
Old 04-08-2013, 09:45 AM
Mine is the same year...starts on the first pull...IT JUST DOESN'T STAY RUNNING TO LONG...
Will do the filter bit and change hoses.
Old 04-09-2013, 08:22 AM
Allow me to suggest thoroughly cleaning both the carburetor AND the fuel pump, too.
Then change the fuel lines to Silverado 4000 Ethanol resistant types.
Use ethanol-free gasoline, if available.
If you must use gasahol, your fuel, if fresh, will not undergo phase separation for 5 - 8 weeks. With Startron or marine Stabil, this is extended to 24-30 weeks, and happens at a much slower rate.
If you just change the gas, and spray out the jets, you've left out the portions of the contaminated fuel delivery system in between.
Fr. Frank says:
Currently without a SeaCraft
