Old 06-27-2005, 12:52 PM
gatorbait gatorbait is offline
Default Mercury Break In Help
I bought 1997 rebuilt mercury 115 with only 9 hours on it. Before I take it out do I need to put 20 hrs on it before going above 4500 RPM? Also should I use mixed fuel, I've heard of this with new engines? If you have any other advice for breaking in this motor please let me know. Thanks.
Old 06-27-2005, 11:24 PM
peterb peterb is offline
Default Re: Mercury Break In Help
Is it under any sort of warrantee?
I have had a couple of engines rebuilt and here is what i was told to do.
1. Disconnect the VRO (and do a straight mix). This was a condition for my warrantee. If you have the VRO hooked up i would probably leave it.
2. For the first 10 hours double up on the oil.
3. For the first hour just idle the engine at the dock.
4. For hours 2 through 10 stay at 3,500 RPM's or under.
At the end of the break in I changed the plugs because of the rich oil mix.
Good luck.
Old 06-28-2005, 12:42 PM
Abe's Rocket Abe's Rocket is offline
The only thing I would add to that is run the engine at a lot of different RPMs during that 10 hour period.
1986 Seacraft 23CC
etec 250
Portland, Maine
