Old 07-23-2005, 12:47 PM
peterb peterb is offline
Default Re: Advice : 1987 23' seacraft CC
Sounds like a project!!!
Where is the boat located?
How do the deck & transom look and feel? Does it need to be painted?
Old 07-23-2005, 01:12 PM
ceade ceade is offline
PeterB
Going to look at it this afternoon . I briefly scoped it out this past spring in a downpour when he was asking 11,000 for it , looked solid and paint wasn't bad. Boat is located in southern Maine, don't see many around here.
Old 07-23-2005, 05:31 PM
Maineman,
Compare it against this boat web page
The hermco bracket alone is worth several thousand.
Good luck.
Is the transom on the boat that you are looking at open or closed?
Old 07-23-2005, 05:48 PM
PeterB
The transom is open with what looks like apiece of solid aluminum on both sides . Just got back with some pics will post when I figure out how. Hull is in real good shape just a little faded.
Old 07-24-2005, 02:17 AM
captkirby32 captkirby32 is offline
More often than not, you don't have to put alum. on a good transom ? and being in the salvage bussines if the boat rolled or sank you might be looking at weld probs in the fuel cell, corrosion on the welds and so forth if its a alum. tank . so if you want a project go a head if you get the boat for a deal. you might want to think about getting a moisture test on the boat to know about the transom and stringers. good luck
Old 07-24-2005, 09:33 AM
Moisture test will be done when the boat is surveyed this week .Thanks for your help.Price now at 7000.00 could go lower depending on survey results.
Old 07-25-2005, 10:17 AM
Abe's Rocket Abe's Rocket is offline
Maineman-
where in maine do you live? and where is that boat? bristol?
abe's rocket
1986 Seacraft 23CC
etec 250
Portland, Maine
