Old 02-16-2007, 12:04 AM
Bobv Bobv is offline
Default Re: A New Boat to Check Out
The foredeck was in pretty bad shape with the support underneath completely rotten. The support was removed and a new one made of foam core was placed. It really stiffened things up so that cracks in the transition between the deck and liner could be properly repaired.
A very meticulously engineered jack system was used to level the deck while the new support was glassed in place!
Most of the hatch covers are also being finished up. In each opening, wood has been laminated into place to receive the hinge screws. This is a picture of wood placement in the forward fishbox. The wood strips running lengthwise are simply wedging it into place until the resin dries.
Hinges are trial-fit in the transom baitwell and cooler boxes.
I'll get some more pictures up soon.
Old 02-16-2007, 10:21 AM
WillyC WillyC is offline
Looking good Bonefish. That boat is gonna be super sweet when its all said and done.
Old 03-29-2007, 09:46 PM
flash14 flash14 is offline
does anyone know where to get the scupper plates bonefish is using for his through transom scuppers? I have been looking and haven't had any luck yet. thanks guys!
Old 03-30-2007, 12:09 AM
http://www.classicmako.com/forum/top...TOPIC_ID=15443
Old 03-30-2007, 11:30 AM
you tha man strick! Is this guy the only guy I can get them through? I only live 20 minutes away from him. Thanks again.
Old 04-25-2007, 02:58 PM
Most of the fairing (except for the floor) is now being finished up.
High build primer.
Underside of the bow. Holes have been pre-drilled for the anchor roller and the rub rail.
Old 04-26-2007, 10:41 PM
Trayder Trayder is offline
Velvet Jones
wow
