More dumb questions; On the 23 Sceptre where is the plug? I cant figure it out. Also Its an I/O if that makes a difference.
mo then likly inz the loose hoze u donut nose
wher whatz it fer. sam |
I just need to know what compartment to look in for the drain plug, if you can be helpful please. Thanks in advance.
If there is not a rubber plug on the lower end on the back of the transom, there should be a threaded brass Garland plug.
Take an adjustable wrench and remove the plug. Ken
See ya, Ken © |
Thanks Bones, so I should look on the transom near the bottom?
Yes....on the transom near the bottom of the V....usually a slight amount to one side because of the keel on the inside.
By slight I mean a couple of inches. |
