Old 06-06-2009, 05:42 PM
Default Re: Question about clay for radius's in one off molds
Do not use anything with water in it. Use only non hardening clay..it is usually oil based. Make sure you put a couple good coats of PVA over your clay radius otherwise the glass will alligator. SuperSculpy is a good clay for small projects and it can be found in the craft stores... Composites one sells a commercial clay that works really well for larger projects.
