I think 52 and25 to28n cruise my scepter goes 46 with 250 suk
Today was seatrial day and with 2 people 60 gallons of fuel cruise speed was 31 with a 9 gph which comes out to a little over 3 mpg Top speed was 51 (6000 rpm)turning a 16 by 18.5 inch stainlees three blade. Dealer claims should pickup more mpg and speed once the engine breaks in. So nice to walk in the back and not have water come in the scuppers like the twins did. Digital gauges are neat and the fly by wire is refinitely a new experience. Will play more with it this weekend to learn the new digital gauges.
That is awesome performance. 3 mpg @ cruise AND a 51 mph WOT - That is outstanding!! Only 9 gph at a 31 cruise WOW.
Makes me want to get a 300 Zuki!
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
![]() Quote:
2.08 ratio 6000 rpm 18.5 pitch prop would give you a top end of 46mph with 10% slip or 48mph with 5% slip. Doesn't Rev Limiter kick in at 6100 or 6300? It's tough to look down when you're moving that speed!! but GPS doesn't lie . . . so you are probably hitting 6300. http://go-fast.com/Prop_Slip_Calculator.htm |
Those are the numbers the rigger/dealer gave me on their two test runs via the Suzuki speedo. I will be playing this weekend and see what the performance is. All electronics out of boat so I will look for a handheld gps to give me some true indicators. I would think if it was up against the rev limiter they would bump up to a 20.5 inch wheel to get the revs down
I thought those #'s were optimistic / inflated. I'll be curious to see if they are the actual figures in the real world and not out of the salesman's mouth. Hope it pans out.
