I doubt it, too.
Not a new factory job. I guess its possible the factory took it in and did the work but I doubt that, too. My Seafari has a plate where the transom was partially raised, but it's solid. On the other hand, the Seavette I just bought has big old plates that the seller said they were configured by a naval engineer to better handle the stress of bouncing 800 lbs at 65mph. I said yeah, whatever, and told him that will still need a new transom. I'll try to post some pictures pointing out why it's really there.
Thanks for the info. I figured he was full of it but maybe he bought that story along with the boat. Will probably go check it out this weekend.
You are right!!! He's full of it or was BSed by the other owner. Bottom line.......a transom repair is around $3000+ done by a repair shop or $1250+ if you do it yourself. I would figure that in during negotiations.
![]() Quote:
You might be able to make a deal on having it done. Negotiate.
