Old 11-21-2011, 08:57 AM
Wildman Wildman is offline
Originally Posted by thehermit View Post
are you planning for trim tabs?
If you arn't, you should be! Leave room for a set of Volvo QL tabs.
I would not shorten that bracket any, here is a picture of the clearance between my transom and 225 oceanpro, tilted all the way up. Its mounted on the lowest hole right tight to the top of the bracket. I may have an issue if I have to bump it up a hole, I dont want to think about what would happen if the bracket was 3in shorter!
