Old 10-07-2012, 10:04 PM
martin martin is offline
Hi shine you can try this for blending paint. No over spray when i did it.. Although it was fresh paint, it came out flawless..... Take some 2 " tape and stick one edge.. Them gently roll the other out .. Do not stick the other side just flare it out to you.. You can also stick it to some visqene to help with overspray.. Or mask off area then come back and apply the flare....i used this method on the bow of a 38 ocean... Had to reshoot cause of print through..
Old 10-10-2012, 02:05 PM
shine shine is offline
Moderator
Thanks for the tip Martin, it makes sense. I dont spray though just roll and tip.
sanded primer to 320, brushed on a couple thick coats of sterling today. Got some contaminates in the paint and there are some bad fish eyes. Not too concerned with them (or the sags) right now, just trying to build a base. Tomorrow I will sand the paint, and put two more coats on, but they will go out wider. My idea is to bring the next coats out further so there is more paint built up for when I try to wet sand and buff the transition out. If that does not work, then I will repaint the whole side. Trying to avoid all that
it looks better in the pictures than in person
system three primer sanded
couple of coats of sterling ice blue, just bushed on
Old 10-11-2012, 05:20 PM
Banjo2 Banjo2 is offline
Hey Shine, did it turn out to actually be a jet-ski that caused the damage? Regardless, sure am glad they ran him down.
Old 10-12-2012, 09:58 AM
Moderator
Yes, it was a seadoo to be specific Driver was eventually found and got a fine and probation for leaving the scene of an accident.
