Old 11-29-2014, 08:57 PM
pelican pelican is offline
Originally Posted by keith View Post
Pelican,
Thanks a lot for your recommendations! It is nice to have access to people so knowledgeable on this site. I replied to some of your comments below.
Thanks, Keith
Good call. Will do.
transom cut out - look inside the boat - it's where the transom was cut out to allow the transom assembly to fit...
thu hull - it's on the port side - looks like maybe a bilge pump outfall ?? it looks like it's plastic...
that other set of pictures - the prop was black - looked like a standard aluminum prop
lenco trim tabs - the actuators often fail - due to water intrusion -actuators not the tab screws
bilge pumps - NEVER share thu hulls !! separate thu hull for bilge pump exits !! smooth hose as well !!
