Old 07-07-2016, 04:26 PM
smilinmatt smilinmatt is offline
Default 1989 23' Sceptre parts
I have a 1989 23' Sceptre that I'm going to be converting to a CC (It's Tracker-era, so I'm allowed to do that, right?). Everything except the hull, trailer and fuel tank are for sale. Until I sell the motor, I'm not going to part out anything I need to run the boat.
2001 Yamaha 225 OX-66. The motor is a 25" shaft, and includes a 17 pitch prop, wiring harness, key switch, binnacle, remote oil tank, and tach w/oil level. Exact hours are unknown, but the motor was bought used in '02, and there are 413 hours on the meter. The motor is still mounted on the boat and can be test run. $4500
Aluminum radar arch with stainless steel bimini. The top and frame are in good condition. There's some oxidation on the aluminum, but structurally everything is good. $800
Hynautic steering system. The previous owner had it "recently resealed". I've used it for about 6 months without needing to add fluid or pressure. $500
Fuel tank cover - just recored with foam and biaxial from Gulfstream composites. $100
Fuel access cover with pry-out plate - just recored with Meranti BS-1088 and biaxial $50.
Stern cover with livewell. No plumbing, "livewell" is just the hatch and tub. This was solid and didn't need recored. $50
If there's any other parts you need, let me know. I do have cushions for the cabin. I'll take those out and get some pictures as well.
You can contact me at:
Matt 813-375- one eight three zero
I'm located in Apollo Beach (Tampa area)
Paypal transaction ID: 3NK32478JD322984L
(Don't know if this qualifies as a "boat" sale, but since I'm selling the top half of the boat I figure it's close enough).
