Old 11-16-2016, 01:38 PM
Originally Posted by davids495 View Post
Nice Graphic Captain Chuck!
I did a search for Carl's wet feet solution but didn't come up with anything. Can you point me to the thread?
Am I correct that you are suggesting I patch over the current drains as they come out through the bottom of the hull and then just below the floor, cut the down tube and put an elbow into it so it goes aft. Then run tubing to flaps out through the transom on the opposite side of the boat?
Are the current flood drains typically above or below the waterline when the boat is at rest with no one aboard?
Yes, plug existing thru hull drains.
if you search "scuppers" or "floor" drains you will come up with more reads than Hillary's emails. I don't remember as I had a 23'. so you need to filter them some how to see solutions / pictures from other members who have a 20
footer that have changed their scupper config to a suitable solution.
Someone help here like "NoBones" please
