Visited the Sea Hag at the fiberglass guy's shop for an update.
The job is 80% done, with gelcoat and drain plugs to install yet. Here are a couple of shots of her with the new higher transom (25 inches). |
Wow, she's looking great! I love the raised transom.
Can't wait to see the finished product! |
Here is the transom nearly done. Main drain plug installed, 2 more to go - the motor well and livewell. Gelcoat needs a bit more clean up, then I bring her home. Will need to touch up the bottom paint where the primer is, weather permitting.
Is the teak trim on the sides salvageable? That would look sweet cleaned up and varnished.
1975 SF18/ 2002 DF140 1972 15' MonArk/ 1972 Merc 50 http://i833.photobucket.com/albums/z...photos/SC3.jpg |
It is not clear whether the teak trim can be brought back from the current sorry state. Next spring, I will try to strip and sand it, but it might have to wait until after the fuel system, steering, wiring and lighting get installed. Oh, and a motor!
Teak is amazingly tough and durable wood, but I would not use any of the commercial cleaners on it, as they destroy the soft parts of the grain and will leave a very uneven surface. Been maintaining it for over 41 years on my boat, and I've found that your best bet is to just sand and varnish with about 6-7 coats of Epifanes Wood Finish Gloss. I've tried teak oil, Deks Olje, etc. and all the oils oxidize and turn dark after just a few months. Epifanes will last many years, especially if you keep a cover on boat and is by far the lowest maintenance in the long run. The urethane varnishes may be even more durable, but when they go, it's a LOT more work to restore them! I varnished the mahogany emblem board below about 8-9 years ago and it still looks good, despite the high UV exposure in S. Fl.!
Oh, and "Sea Hag" may be an appropriate name for an ugly boat, but the Seafari is NOT an ugly boat! I think you can do better!
![]() Quote:
