Old 11-06-2019, 08:01 AM
My 18 had a piece of plywood about 4" x 4" between the box and the hull with the drain fitting centered. I imagine they did all of them that way.
Old 11-06-2019, 11:36 AM
steel686 steel686 is offline
On my 18 there is Potter Putty against the hull and about a 1/2” gap if I remember correctly. When I bought it 27 years ago, I would get a lot of water in the bilge and found the flared copper thru-hull was loose. Even though it was above the water line, I removed it and the problem went away. I think the flex in the hull made it a weak spot. So I glassed it over and drained box to bilge. About to rework it during the rebuild.
Old 11-06-2019, 05:22 PM
Like mentioned, normally the flared threw hull is in a piece of wood between the two. May have potter putty between the two or around the wood block.
Old 11-11-2019, 09:28 AM
I do see a 4x4 plywood block up there as well. I don't use that space as a fishbox so draining to the bilge might not work for everyone. Think I will plumb a line back to where I can see it drain or plug it.
Old 11-11-2019, 11:17 AM
There was still some of the plywood was there, so I filled the void with 5200 and installed a larger cast bronze thru-hull fitting. I had to hone the inside of the fitting so a plug would seal up.
http://www.classicseacraft.com/commu...1&d=1573485386
http://www.classicseacraft.com/commu...1&d=1573485418
