Old 06-16-2004, 09:07 PM
newboater newboater is offline
Default Gel coat
How do I repair damage to gel coat finish ??
Frank 1972 20' Seafari
Old 06-16-2004, 11:17 PM
Rich Rich is offline
Default Re: Gel coat
With a piece of sand paper and some Gel Coat... [img]/images/graemlins/grin.gif[/img]
Cape Marine Supply
Old 06-17-2004, 09:23 PM
Never worked with gel coat before, is it similar to auto body putty?? do you need any special equiptment?? will it take long to cure??
Old 06-17-2004, 10:58 PM
Scott Scott is offline
Its Polyester resin with pigment (white).... with the consistency of latex paint....Curing time depends on amount of catalyst added and temp you are working in
Can be sprayed (better for large areas) allowing for a “ smoother” surface .... It can be rolled but the result usually leaves more of an "orange" peel surface which means more sanding to get smooth glossy surface.
Depending where you intend to use it would drive how I would apply it ..... I rolled (with a foam roller) the undersides of recored hatches .... I really don’t care how the surface comes out on the underside.
Old 06-18-2004, 10:41 AM
Rufridr069 Rufridr069 is offline
“ smoother”
HUH?
Wasn't there, ya didn't see me, ya can't prove it! [img]/images/graemlins/cool.gif[/img]
Old 06-18-2004, 12:34 PM
“ smoother”
HUH?
I think Scott is having technical difficulties. I got an email from him the other day and it contained the same thing.
Then again, it could be some type of secret Joisey lingo! [img]/images/graemlins/tongue.gif[/img] [img]/images/graemlins/laugh.gif[/img]
Old 06-21-2004, 10:50 PM
What??? that didnt make perfect sense [img]/images/graemlins/grin.gif[/img]
Hmmmm .... Wonder what I did ..... Must be sniffin to much resin again [img]/images/graemlins/cool.gif[/img]
“ smoother”
HUH?
Lets try pictures .... I like pictures [img]/images/graemlins/grin.gif[/img]
From this..... no gelcoat
To this....... gelcoat
