Old 08-13-2004, 01:54 PM
Mooncusser Mooncusser is offline
Default Factory Installed Bracket?
The broker on this claims this bracket was factory installed. It's on a 1987 which I assume is a CSY hull? Has anyone ever seen this? it looked like an I/O conversion to me.
Old 08-13-2004, 03:12 PM
Default Re: Factory Installed Bracket?
I/O conversion... and a Mako console too
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 08-13-2004, 04:01 PM
gw204 gw204 is offline
Cute.....
Nice half skeg on the motor.
Looks to me like the tabs are not lined up with the bottom of the hull. I'm aware of the variable deadrise thing but those tabs are almost parallel to the ground.
What kind of rollers are those right above the fenders? Are they some new type of poly? [img]/images/graemlins/laugh.gif[/img]
Brian
1981 Mako 17
Old 08-13-2004, 04:21 PM
it's a gill bracket . . . not sure if those were factory with tracker . . .
Old 08-13-2004, 04:22 PM
What's with the wood wedges on the fender of the trailer?
Old 08-13-2004, 04:39 PM
John R John R is offline
Yep - all of the above - Mako Console & original style and I've read, often splitting, Gill bracket. Looks like it offers 6 pounds of floatation [img]/images/graemlins/tongue.gif[/img] But it is on Nantucket - is that where you are?
Surf and Boat fishing for
Striped Bass
Old 08-13-2004, 05:19 PM
Tell the broker he is mistaken. It is an I/O conversion. GIL marine was exclusively aftermarket back in '87.
However, in 1988-90, the GIL bracket was offered as a factory install on the 6 of the 34' Wellcraft Scarab "Raider", a boat that was available only to law enforcement agencies and the military.
I rigged 4 of them.
Old 08-13-2004, 07:05 PM
It's not a CSY manufactured Hull either
Old 08-14-2004, 09:01 PM
warthog5 warthog5 is offline
Those old Gill brackets were made of steel and they liked to rust from the inside out. Gill doesn't even make that style any more.
Not much get's by you guy's. Good eye.
I'm guessing on the wood wedge blocks. Maybe a roller broke.
Old 08-15-2004, 07:47 AM
jfm jfm is offline
It looks like someone just set the wooden wedges up on the trailer fender. Probably used as chocks for the tires.
