Old 09-19-2004, 04:52 PM
Finster Finster is offline
Default Deck drains
For what it's worth. The Seavette came stock with deck drains that run through the transom. They are in the same place on the deck, but they put a 90 on it and ran it straight back. They sit way under water, so Scott and I put on a set of ball scuppers and it works like a charm.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 09-21-2004, 08:03 AM
Sleeto Sleeto is offline
Default Re: Deck drains
Chris,
Where did you get the scuppers?
Thanks
Old 09-21-2004, 08:10 AM
You mean the ball scuppers? They are standard issue, most marina's or dealer should carry them.
'76 23 SC CC I/O
Old 09-21-2004, 11:29 AM
Scott Scott is offline
Rabud
Bottom right corner
Boatfix.com .... but like finny says ..anyone should have them ....
They do work well
Old 09-21-2004, 03:43 PM
pogden pogden is offline
Chris,
For what it's worth. The Seavette came stock with deck drains that run through the transom. They are in the same place on the deck, but they put a 90 on it and ran it straight back. They sit way under water .....
I guess that's not self bailing....????
Then again who needs self bailing with 300 horses [img]/images/graemlins/grin.gif[/img]
Worry less, Fish more!
Old 09-21-2004, 05:26 PM
Pat
My '78 came from the factory that way also (90*) out the transom (I posted this pic earlier on another post) That's strange that Finsters are that way also. When Mr. Potter was on my boat this year, I showed him mine, he told me that they didn't come from the factory out the transom.
BTW: They self bail just fine without the ball scuppers
Old 09-21-2004, 07:11 PM
That dosen't look like same config as mine. I'll have to stick a camera down there and see if I can get some picks.
Plus, there is no indication of anything filled or patched on the bottom of the hull.
I was looking a pic's of Scotts threw hull's and the fittings where the same.
The only thing I can think, was they did it that way on the Sevettes because of the additional weight.
'76 23 SC CC I/O
Old 09-21-2004, 08:51 PM
I don't see a patch at the bottom either even thou the hull indentation on the outside is still there. I cut in the tee you see spiced into the drain. I added a gutter system in the floor deck hatch so any water would run off to the floor scuppers vs sealing the hatch. You can see the drain holes in the aft corners
Old 09-21-2004, 10:05 PM
Hummmm, vaguely famliar...I'll have to look a little closer.
My olny experience with a 23cc's guts is in my other one with a twin i/o setup. That whole deal in the stern is very different.
It wasn't until Scott showed pictures of his. that I saw the simularities.
And...I'm still be willing to bet that, that setup in the vette is stock.
'76 23 SC CC I/O
Old 09-21-2004, 10:51 PM
When Mike replaced my transom he ran them out the sides. they work great,and no worries about it damaging the transom by going thru it.I wish they would of done them this way in 1973, I probaly would of still had a transom. [img]/images/graemlins/crazy.gif[/img]
