Old 10-17-2004, 09:19 AM
runamuck runamuck is offline
Default water in fuel
I have a 1998 21cc Seacraft & I am having trouble with fresh water getting in the fuel tank.I have checked all lines & fittings & they are OK. The fuel tank vent is attached to the fuel fill with a vented fuel cap.I think this set up is my problem. Looking for advice
Old 10-17-2004, 02:49 PM
Mark Mark is offline
Default Re: water in fuel
A friend with a year 2000 20' Master Angler had the same problem. The cause of his was determined to be some rather creative routing of the fuel and vent lines: in rough conditions, he took a LOT of water into the fuel tank [img]/images/graemlins/shocked.gif[/img]
Old 10-18-2004, 08:38 AM
runamuck,
Do you have a fuel/water separator? If not, it's a good idea to install one even if you still have to re-route the fuel and vent lines. This way you can be fairly certain that contaminated fuel won't get to the engine. Another way to prevent/detect water in your gas is to install a sending unit from WEMA , which will detect water before it gets from the tank to the water separator. Plus, you'll get a much more accurate reading on your fuel gauge.
Old 10-18-2004, 08:49 AM
The fuel Vent line should have a U shape in the hose allowing water (if any water can get into it from the ocean) to be trapped in the U it kind of looks like this.
boat vent location ----- U ------ inside location of hose (the U should be located lower on this example)
This belly of the hose traps water in the U and keeps anything from intering into the tank.
FellowShip [img]/images/graemlins/grin.gif[/img]
Old 10-18-2004, 12:47 PM
RS RS is offline
I'm pretty sure it's the opposite. The vent line needs a riser loop to prevent water from entering the tank. Accumulations of water in a trap will ultimately be sucked into the tank.
Best regards,
Roger
1979, 20' Master Angler
