Old 03-08-2005, 02:19 PM
JoeHahn JoeHahn is offline
Default Transom Bracket
I have recently purchased a 23" Center Console (1979). To gain more cockpit space I am consdering cutting down the motor well or adding a transom bracket.
Has anyone added a bracket ( like Toirans project ) as I would like to know how performance in rough weather, handling and performance are effected. This boat had no power so I am also open to recommendation as to power.
Thanks
Old 03-09-2005, 09:30 AM
Default Re: Transom Bracket
Welcome CaptJoe to CSC [img]/images/graemlins/smile.gif[/img]
There are many threads you can read reference your refurbishing ideas by using the "Search" function.
I am in the final process of a transom redo and bracket install at this time. Go here to view some pictures ----> New Bracket
BTW; Don't forget to get your 1979 Potter Built HDS ----> HDS
Old 03-11-2005, 01:27 PM
Capt Joe, overall everything is better. Handling, room, performance,its a completly different boat, you wont be sorry if you add a bracket. I personally would close the transom (full)but I have seen where a bracket was installed and kept the cut out,if you dive this is nice because you can just step in without having to go over the full transom.RS.
Old 03-12-2005, 07:30 PM
Thanks for the reply. Is that a potter bracket? If not which one are you using?
Old 03-13-2005, 10:12 PM
Im using an Armstrong wide body. Hermco makes a nice fiberglass one. Capt Chuck is using this one. Whatever you decide to go with make sure its a wide body.
