Old 09-01-2005, 10:51 PM
benhardj benhardj is offline
Default Baystar Steering
I am going to go with a Baystar unit since I will only be running a 150. I hope these are good units. I have noticed that the hoses are 20' long and was wondering if they can be cut or ordered in shorter lengths?
Old 09-02-2005, 01:45 PM
riffraff riffraff is offline
Default Re: Baystar Steering
You cannot cut them as they have fittings on the ends, you can curl it up in the console and use cable ties to secure, or buy shorter hoses.
Old 09-03-2005, 10:39 AM
from the website-
Outboard hose is too long, can I cut it down? NO! You CANNOT cut SeaStar outboard hoses. Take up the slack under the dash, or anywhere else, once that hose is cut, it is garbage.
heres the q and a page-
http://www.seastarsteering.com/FAQs/faqs.htm
http://www.seastarsteering.com/BAYSTAR/baystar.htm
craig
Old 09-03-2005, 12:00 PM
Sorry guys, you can cut them. Find a Hydraulic shop in your town. I had new ends swedged on. Also do a dry run with the hose before you cut it. Mark it, then cut.
Central Hydraulics in Daytona Beach did mine and they have been in the boat for 10 years.
See ya, Ken
Old 09-03-2005, 05:12 PM
if i remember correctly on my seastar it said you could cut them , just make sure they are the same length. the seastar has compression fittings instead of the swaged fittings it looks like the baystar has.
