Old 01-23-2006, 11:10 PM
CaptDavid CaptDavid is offline
Default I guess it's my turn.
I am going to restore a 1973 20ft potter. I was just wondering what is everyone input on the use of foam in a rebuild. I completed my seabird two years ago a used it. Now I am double thinking it use. [image]http://www.myfishingpictures.com/watermark.php?file=500/1522seacraft_inside-med.jpg[/image]
Old 01-24-2006, 02:37 AM
Scott Scott is offline
Default Re: I guess it's my turn.
Welcome to the site CaptDave!!!
Seabird .... hmmm someone’s going to want pictures [img]/images/graemlins/grin.gif[/img]
As for the SeaCraft and Foam in the rebuild ??? How did you intend to use it ??
Up against an uncoated fuel tank, not good !
Give us some details of what your thoughts are.
Lots of great info here .... ENJOY !!!
Old 01-24-2006, 12:34 PM
I was thinking about taking the old out and putting in new.
[image]http://www.myfishingpictures.com/watermark.php?file=500/1522seacraft_inside.jpg[/image]
Old 01-24-2006, 02:54 PM
That would be me! [img]/images/graemlins/wink.gif[/img]
Capt Dave - which model Seabird did you have? I've got a '72 23' CC (V-24 Mariner).
Old 01-24-2006, 05:05 PM
kwluis kwluis is offline
Capt David...here's your boat
www.coolseasfishing.com
2005 Sea Craft 23
Old 01-24-2006, 06:41 PM
warthog5 warthog5 is offline
If it's dry? leave it alone, unless you want to seal the top of it.
If it's wet dig it out and replace it, but save the dry hunk's to put back in with some new added to glue it together.
I understand that the price of 2 part foam has really shot up.
Old 01-24-2006, 06:47 PM
Yes may just leave it be and put in some bulk heads.
I had a 23 tricked out seabird that capt karl and I rebuilt. I posted on the fs fourm and seabird forum under bitsandbytes. Or go to myfishingpictures.com and do a search.
Luis how did you get the pic to work?
Old 01-24-2006, 08:53 PM
Capt David,
I remember seeing your boat on the Seabird site. Very nice work.
Old 01-24-2006, 10:21 PM
Finster Finster is offline
CaptDavid, I personally would take the foam out and leave it out. It has no real benefit. The thought behind it was, if you hit something hard enough to breach the bottom of the hull it would keep you from sinking. That problem can be easily be remedied with a 2k or 4k gph ditch pump in addition to your maintenance pump. And if you hit something where a pump that size won't keep up your gonna sink regardless of the foam.
The foam is a loosing proposition as it will retain water from condensation alone, not to mention other source's.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 01-24-2006, 10:25 PM
Jaizzen Jaizzen is offline
I just pulled a ton of foam out of my 23 footer. It wasn't saturated but it did have water pooled under it. It will not be going back in, no real reason for it to be there.
Best of luck, Jason
