Old 04-19-2006, 11:03 AM
jongolds jongolds is offline
Default Through Hull / Seacock
The Seacock on my NTM 73 Tsunami is frozen open. I was able to remove it and I have it soaking in a oil bath for the week. However, I'm not confident that I'll be able to get the valve closed again with out cracking the casting. It's a nice all bronze casting so I hate to lose it. Any suggestions on how to free it up?
Also, what's the proper method for reinstalling it. I was able to just spin it off the threaded thru hull fitting. Do I just thread it back on. How tight? Any sealant or teflon tape? I'm concerned about spinning the through hull while tightening down the seacock.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 04-19-2006, 09:33 PM
paulfurnari paulfurnari is offline
Default Re: Through Hull / Seacock
Get rid of it and buy a new one. The last thing you want is a seacock that isn't working properly. Install with teflon tape. If your thru hull spins, it's time to redo that also.-PF
Old 04-20-2006, 10:48 AM
The through hull doesn't spin at this point. I was wondering what the odds were of it still being ok after replacing the seacock. ie is it standard practice to replace one when relpacing the other. Sounds like I should be in good shape though ... thanks. Hopefully, some one will have a new valve in stock this weekend if the old one hasn't freed up.
Norwalk, CT
