Old 05-08-2006, 09:11 AM
Skiblet Skiblet is offline
Default Finally splashed
She still isn't 100% complete but I did run her yesterday.
Overall she ran great with these
So far top speed is 54 mph @ 5700 rpm
Best cruise 40 MPH @ 4200 RPM burning 16 gph
This was with two people and a full load of fuel and water.
I will get more numbers and post later.
It was blowing a solid 15-20 with 2-3 foot chops
I Still need to play with the props.
Old 05-08-2006, 10:19 AM
Default Re: Finally splashed
Ha there is nothing like your first trip after splashing the boat. I bet the smiles were from ear to ear.
I was looking at your picture where you placed your bunks on the trailer. You might want to read the post on trailers in the general section that could be a problem for you in the future.
FellowShip
My motto: Just for the Grins
Old 05-08-2006, 12:02 PM
Skiblet-
Nice power. Thanks for the #'s. You must be fired up! You have waited awhile right?
Old 05-08-2006, 12:27 PM
pretty impressive numbers on the fuel burn at 40mph with twins
Old 05-08-2006, 02:05 PM
HatTrick HatTrick is offline
Aluminum Slide On trailers made by Owens and Sons places the bunks over the frame so much of the weight is distributed over the frame not the cross members. I have the same trailer and assume yours is like mine with lots of bunk support under the keel as well.
'86 20 ft CC with 4-stroke 150 yamaha
Old 05-08-2006, 04:53 PM
If you look under the General section there is a thread about trailer bunk placement. The fundamental rule is to place the bunks under the Stringers of the boat like Capt Chuck’s picture shows his boat. There is one member here that had to have a lot of the bottom of his boat repaired because “he said” that his bunks were not placed under the stringers and caused a de lamination of the bottom glass.
FellowShip
Old 05-09-2006, 09:02 AM
Thanks for the heads up on the bunks. I have them in the same place as my old trailer which I had since 1990 and the previous owner had them in the same place on the trailer before.
Regarding the boat you mentioned with the delamination if its the same one I saw it was due to the forward bunks not in the correct area. That trailer had no keel support. The forward part of those bunks were higher than the rear and causing stress points.
Yes, I have been waiting since end of Feb for these engines.
Old 05-09-2006, 09:06 PM
Congrat's . . . must be fun to have that boat cruising 40mph in 2 - 3ft chop.
Old 05-13-2006, 08:41 AM
as promised more numbers
The numbers I posted above were with 19" Rebels.
These are with 21 vipers.
RPM Speed Gal/Hr Miles/Gal
3100 26 10.5 2.6
3500 32.3 12.52 2.58
4000 38 16 2.37
4500 43 21.7 1.98
5700 57.3 ? ?
I tried the 21" Rebels and couldn't get the rpms out of them
I will try the 19" Rebels again and see how they compare.
I would like to try some 19" Mirage Plus if anyone has a set?
Old 05-16-2006, 10:00 PM
Sweet Skiblet! The first twin 200 (non-HO) Etec #'s on a bracketed 23 are looking good.
