Old 02-21-2007, 10:35 PM
oz775 oz775 is offline
Default 2005 225 Optimax prop
Is anyone running a 225 Opti on either a 23 CC or Tsunami/Sceptre? I re-powered last year and dealer said that my old prop from my 1996 250 Merc would work with the new engine.Well- I cant get the new engine to push over 5200 RPM at WOT- All the Merc guys I talked to at the AC boat show said I should be getting at least 5800 RPM at WOT. I am going to purchase a new prop for this year. I am interested in hearing some RPM numbers from other Opti owners and what prop you are running. Thanks in advance
1974 Tsunami- 2004 Merc 225 Opti on bracket
Old 02-22-2007, 12:33 AM
SteveH SteveH is offline
Default Re: 2005 225 Optimax prop
I have a 23 ft seacraft and have a a 225 opti (2000). I have two props; my main prop is a stainless 17 inch pitch prop and it is either 15" or 15 1/2" in diameter (I cant remember but I can check if you would like). It runs 5800 rpms wide open and 43 miles per hr. per GPS. I have a back up aluminum prop which has a 19" pitch and is a bit smaller at 14 1/2" diameter. It runs 5700 (approx) wide open and about 40 miles per hour (gps). I hope this helps.
Steve
Old 02-22-2007, 02:18 PM
I'm running a Mirage Plus 3 blade 15.5 dia. X 17 pitch part # 48-18278A46 on my 23' center console. It turns 5600 r.p.m. 5800 r.p.m. is optimum but as long as you're close you'll be fine.
Old 02-23-2007, 02:44 AM
Just drop 2" of pitch and you'll be golden
Old 02-27-2007, 03:09 PM
kwluis kwluis is offline
I am running a 2005 225 opti with a Mirage 17P. My numbers are almost identical to SteveH. The boat originally came with a 19P, but I was only turning about 5300 rpm or so with ideal conditions.
You can also check out the new Merc Enertia props, I haven't used it since I am happy with my Mirage.
www.coolseasfishing.com
2005 Sea Craft 23
