Old 05-28-2007, 09:30 PM
hobson hobson is offline
Default Bilgekote
I have a quick question, not sure how many off you have used bilgekote, but after I use it, will fiberglass and 5200 stick to the stuff. I figure with a little sanding it should be fine. Thanks a lot.
Old 05-29-2007, 09:55 AM
warthog5 warthog5 is offline
Default Re: Bilgekote
No, the paint needs to come off to add any fiberglass.
Bilgekote is dark and dingy with the Gray. I don't like it.
This is Shurwin Williams "Tile Clad HS" It's a true epoxy paint and designed for direct contact with water.
It's used to paint the inside of water towers.
I covers outstanding and fills the weave of Roven Woven pretty well with 2 coats. Easy to clean too.
Old 05-29-2007, 11:40 AM
mbo_1971 mbo_1971 is offline
hey wart, i think others have used Tile Clad to do under consoles as well. Would you agree this is a suitable application? I want to brighten things up under mine, and thing a bright white would help a bit. Also, do you have a source for Tile Clad? Thanks.
Old 05-30-2007, 12:25 AM
My bilge. inside consoles & the whole inside of the cuddy is painted with it. Anywhere not in direct sunlight. The UV rays will work on it, as it is a true epoxy.
Local Shurwin Williams paint store.
Old 05-31-2007, 01:00 AM
Fishjack Fishjack is offline
To answer your question - you will need to sand down to bare fiberglass to ensure good adhesion with any fiberglass resin (epoxy or poly). I used white Bilgekote in my bilge with good results - I liked it because all I needed was a quart or two and did not have to spend the $$$ on a gallon of paint. Saved that $$ for fuel..
1977 23' Superfish
ST250x Yam
