Old 07-25-2007, 07:17 PM
joseenriquec joseenriquec is offline
Default Transom work for 20' sceptre .
I'm ready to do fix my boat, I bought this in really bad condition. But the transom I belived need to get replace. My question is "HOW" and this sea cratf came with a 302 ford engine. How bad is this? I took the engine out to re-built it. I take any tips help money what ever
thanks
Old 07-25-2007, 08:18 PM
RODMAN RODMAN is offline
Default Re: Transom work for 20' sceptre .
You came to the right place, just do a search and you will find the answer, its all been done and you'll get good ideas also. Good luck.
Old 07-25-2007, 09:55 PM
ocuyler ocuyler is offline
thanks
Us too...
Otto
Old 07-25-2007, 10:10 PM
BigLew BigLew is offline
Otto,
"Each ding in the hull requires 2 times the beer to fix as it does to create..."
...and hear I've been budgeting 1 case for the repair crew for every beer that is guilty of "contributory negligence"!!!! What's your secret, man?
Plan accordingly!
Old 07-26-2007, 05:25 PM
captinseafood captinseafood is offline
Hey SeaCrafters! I'm in the midst of replacing the transom of my '74 20ftcc. I've cut out the rot and preped the remaining glass to accept the 2 pieces of 3/4" marine ply I'll be laminating with West System 205&105. My Questions: 1. Do I fill all gaps between hull interior and ply with epoxy with or with out filler & fibers? 2. Should I stretch the fiber sheet over and around the outside of the hull? 3. if so, how far over the exterior? 4. How much should I flare out the seam between hull and transom, will that effect how the boat planes? Any thoughts?
Old 07-26-2007, 08:14 PM
Can we see some pictures.....
Old 07-27-2007, 08:28 PM
Greetings! I actually got some advice from a friend. I'll post some pictures of the project for review soon. Thanks!
