Old 08-15-2007, 05:28 PM
aceraccoon aceraccoon is offline
Default Engines
I have a 1973 CC I/O. I currently have a 1994 Mercruiser 350 Magnum Engine with a Bravo-1 Outdrive. Does anybody have any thoughts on better set-ups? Is there a more powerful engine available in a similar size? Thanks.
<a href="aoladp://MA12375676-0003/img001.jpg" target="_blank">aoladp://MA12375676-0003/img001.jpg</a>
Old 08-15-2007, 05:33 PM
Default Re: Engines
There are deals on the 383s to be had.....325HP. You can try www.go-fast.com.....as well as some of the other Merc authorized dealers on the net. I almost went that route but went closed cooling MPI.
Old 08-16-2007, 09:12 AM
bigeasy1 bigeasy1 is offline
Default Re: Engines
Like Bayouboy,i also found some good prices on the 383Mag 325hp setups online.Go-Fast seemed to have the best prices of all that i checked.
I ended up buying another boat just for the engine and drive.Saved a lot of money,and it has less than 200hrs.
Are you unhappy with the engine and drive that you currently have?,are you thinking of replacing it?
I would love the 383MAG and Bravo I or Bravo III package,but couldn't justify the extra expense after i found this used setup. If money was no object,and i was going to stay with a Gasoline I/O, i'd give a serious look at the 383.
If you're thinking of getting rid of your current engine and drive,i know someone looking for that same thing.
All this,just for a boat ride
