Old 08-02-2008, 02:56 PM
Default Filling screw holes in Seafari transom
There are about a dozen screw holes on my lower transom from old transducers and clips, etc., I want to fill them. I have epoxy and some talc thickener, 3M 4200 fast cure, and regular 3M 5200. Which if any should I use to fill the holes? Holes are about 3/4" deep size 10 or so. Should I drill them out before filling?
Thought I'd get some feedback before doing something stupid. Thanks -Gillie
Old 08-02-2008, 03:09 PM
nos3665 nos3665 is offline
Default Re: Filling screw holes in Seafari transom
talc I think is the stuff used in Bondo, and should not be used below the waterline. Epoxy with the correct filler is the best bet.
look here for some more info, http://www.jgreer.com/index.htm
Old 08-02-2008, 06:33 PM
Thanks for the heads up on the talc. I got epoxy from John Greer to fill a bunch of holes on the gunwales, dash and floor. Should I get some cabosil or can I use some 4200 or 5200 to fill said holes; or is there something else I should use?
Old 08-02-2008, 06:51 PM
For filling screw holes, try this stuff
http://www.marinetex.com/PRODUCT%20P...rod%20info.htm
Old 08-02-2008, 08:50 PM
make sure you drill them out a little to give the epoxy a better bond.
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 08-02-2008, 11:17 PM
kennmazz kennmazz is offline
Drill them out a little. Grind back the gelcoat about half an inch around. Fill the holes with Duraglas. If below the waterline, cover the Duraglas with resin or epoxy. Sand smooth and recoat with gelcoat.
"To know what is right and not do it is the true cowardice." -Confucious
