Old 10-28-2008, 10:06 PM
3rdday 3rdday is offline
Default High speed water pickup- placement /interference
I am finishing the rigging on my 21 wanting to solicit the experts on the placement of the thru -hull high speed water pickup for my baitwell. I am very limited, I can only place it on the most inboard set of panels. I am concerned that it could interfere with the water pump pick up/ inlets on the outboard, by possibly parting the water or aerating it causing the outboard to overheat. The outboard inlets are set back about 36" from the transom as the outboard is mounted on a bracket. On my last boat with a bracket, I had the transom mount transducer interfering with the water intakes and would get an overheat alarm because of this I also had some prop cavitation? as the transducer parted water and introduced air. Will this pickup interfere as the transducer did?
Old 10-29-2008, 10:13 AM
Default Re: High speed water pickup- placement /interference
Gem products makes a sweet flush mount pick up. Only about 1/4" profile, unlike the usual bronze bulge.
Nice work on the 21.
GFS
Old 10-29-2008, 07:46 PM
BigLew BigLew is offline
GFS
I lookd up the cost on that sweet thing, a "C note" plus! That is one nice OUCH.
Plan accordingly!
Old 10-29-2008, 09:15 PM
Thanks everyone for the help and the kind comments.
Old 10-30-2008, 09:48 PM
toddslures toddslures is offline
Check your pm's for your quote on the GEM high speed pick-up, #87002.
www.toddslures.com
Old 10-29-2008, 11:50 AM
The thru-hull needs to be spaced minimum 8 inches outboard of the hull centerline, and as far out on the bottom-most planing surface as possible. This should prevent excessive ventilation.
Old 10-29-2008, 09:55 PM
I have an acocunt with them I will send you a quote for the h20 pick up.
www.toddslures.com
