Old 04-09-2009, 09:44 PM
Marmaduke Marmaduke is offline
Default outboard brackets
I need some opinions on fiberglass versus aluminum on outboard brackets. I want to put either a 300 hp Suzuki or a 250 Yamaha 4-stroke motor on a 23' center console.
Old 04-09-2009, 11:16 PM
Default Re: outboard brackets
Contact Don Herman on this site. His brackets for SeaCraft are reputed to be the best.
Old 04-10-2009, 12:18 AM
Unless you enjoy fighting corrosion, I'd go with one of Don Herman's fiberglass brackets! The salt seems to eventually get to the aluminum brackets, even if they're powder coated or painted with epoxy. Don's brackets also have the biggest flotation tank, and he's dropped his prices quite a bit since he now owns the molds and makes them himself, so I think you'll find that he's quite competitive on price.
Old 04-10-2009, 08:14 AM
BigLew BigLew is offline
IMHO - If Don is at all competitive, and I believe he is very much so given the quality of his work and product, I think he deserves the business just for all the good information he provides all of us "at no charge."
Just my 2 cents.
Plan accordingly!
Old 04-10-2009, 05:08 PM
Long term corrision will start on the aluminum...you have to bolt anodes to them to help. The soft curves on the fiberglass bracket look better to...and Don's is made for the SeaCraft.....
Old 04-10-2009, 08:15 PM
SeaMaster SeaMaster is offline
Go witht the fiberglass one from Don, you wont regret it!! Heres ours that he did.
http://img.photobucket.com/albums/v7...6/582ba35a.jpg
1979 23 cc SeaCraft twin Yamaha 200 HPDI's
1999 16 Carolina Skiff
2006 4x4 Titan
Old 04-11-2009, 09:53 AM
small45 small45 is offline
Although I have not installed mine yet, I have to say the craftsmanship of my Hermco bracket is outstanding. I think if you compare apples to apples, you'll find they are the better value.
Old 04-11-2009, 05:10 PM
Notwithstanding the fact that if you install a bracket without flotation chambers, the cantilever effect of the bracket will create more downward force than the same motor connected directly to the transom.
Will
