Old 04-14-2009, 12:27 PM
nightwatch7 nightwatch7 is offline
Default Finishing the inside of gunwale rod racks-- 20'MA
I have 1984 20' Master Angler and have taken the factory carpet off the hull under the gunwale rod rack area. What are people doing to finish that hull area. I see some finished boats that appear to have a nice smooth finish to that area. Are they using skin material and gluing?
Old 04-14-2009, 01:57 PM
PressureDrop PressureDrop is offline
Default Re: Finishing the inside of gunwale rod racks-- 20'MA
for my undergunnel rod racks in my seafari i gelcoated the fiberglass (did not waste my time sanding perfect) and added green and yellow splatters (yellow hull/green bottom), i think i looks good and doesnt require a tremendous about of finish work, its one idea...
no falls, no balls
Old 04-14-2009, 11:21 PM
ROBCAR ROBCAR is offline
what I did on the redo of my 1978 MA was to mold some fiberglass skins with a gelcoat finish, using the outside of the boat to get the right angles, then I secured them in place using mat and resin.
here is are some pics to give you some idea
Old 04-15-2009, 12:38 PM
I would just put some carpet back in - the other options seem alot of work - maybe you could figure out another major project
Old 04-15-2009, 10:40 PM
yes, that will be a option too.....and much cheaper
Old 04-16-2009, 12:24 AM
I like my black carpet adds a tad of color to the boat mostly
sure wish I could get somebody with a MA to trace those rod holders on a piece of paper though
Old 04-17-2009, 08:06 AM
i used the old carpet to trace the pattern for the mold.
Old 04-24-2009, 10:13 AM
WillyC WillyC is offline
How about gluing a piece of formica in there. Cheap and easy. Holds up well and easy to clean. Comes in any color you want.
Old 04-24-2009, 11:44 AM
waytogo waytogo is offline
How about cutom seadek panels with the seacraft name cutout
Old 04-25-2009, 12:46 AM
willydewitt2 willydewitt2 is offline
Clean all the glue off from the carpet with wire wheel and then paint it. Primer will fill in a lot of imperfections. When you are done, you have a slight texture of the original woven roven pattern shining through. It is easy and I think looks great.
I have a 20' SeaCraft master angler 1976. Looking for more ideas on this great website.
