Old 04-27-2009, 10:43 AM
Splitseas Splitseas is offline
Default Removing Stern Cleat
Guys,
I'm having trouble getting to the washers and nuts under the port side stern cleat on my 20' CC. I'm trying to replace the cleat. This is the one on the same side as the livewell, so you can't access. Does anyone have any suggestions on how to get in there to get a wrench on the nut? Thanks.
Old 04-27-2009, 12:59 PM
Default Re: Removing Stern Cleat
Maybe use toggles - I have a Master Angler and haven't figured out how to at anything in the corner
Old 04-27-2009, 01:05 PM
datngrizz datngrizz is offline
How about drill out the bolt from the topside. The nut will drop down. Replace with a toggle. May work...
Old 04-27-2009, 04:46 PM
mnwnvc mnwnvc is offline
Drilling works fine until the nut, washer and bolt start to spin. Now you have the same problem and an ugly bolt head. You could cut the cleat and bolts with a sawzall but I do not have a good solution for replacement.
Old 04-28-2009, 08:38 AM
ROBCAR ROBCAR is offline
I drill an small access hole with a hatch (about 4") ... figured that would be the best way to get to the nuts and washers.
Old 04-28-2009, 01:40 PM
Inside the baitwell? that just gave me an idea to get at the stern ring that drips rust on mine - of course the one with no access issues doesn't do it
