Old 06-06-2009, 12:13 PM
PressureDrop PressureDrop is offline
Default Question about clay for radius's in one off molds
strick or island trader or anyone else in the know - is there a special kind of clay you use to do the radii or will good old sculpting putty from the craft store do?
Thanks
no falls, no balls
Old 06-06-2009, 03:17 PM
Default Re: Question about clay for radius's in one off molds
To be honest I really do not know. I would think yes.
I used a product called Klean Klay. I got it from the fiberglass store.
The only thing they said is to use clay and never caulk.
Klean Klay
Also for easy radius use something that is round...like a ball bearing on a handle.
Radius Tool
Old 06-06-2009, 05:42 PM
Do not use anything with water in it. Use only non hardening clay..it is usually oil based. Make sure you put a couple good coats of PVA over your clay radius otherwise the glass will alligator. SuperSculpy is a good clay for small projects and it can be found in the craft stores... Composites one sells a commercial clay that works really well for larger projects.
