Old 07-18-2009, 11:26 PM
Dilligaf Dilligaf is offline
Default Adding another gas tank??
if i wanna add a gas tank so i would have 2, how would i switch between tanks? some kind of mechanical valve?
Old 07-18-2009, 11:31 PM
BigLew BigLew is offline
Default Re: Adding another gas tank??
Two stopcock valves, one on each tank and then a 4 way stopcock valve which would let you choose tank A or B or both on or both off.
Plan accordingly!
Old 07-18-2009, 11:45 PM
Make those stopcock valves Ball valves. stopcock valves are used in small bore tubing in hospitals and labs - sorry, just something I have had dealings with and didn't think anything of it at the time.
Shutoff valve at each tank and then the multi-port valve taking in either tank and out to the engine.
Plan accordingly!
Old 07-19-2009, 12:01 AM
are these valves turned on and off manually?
Old 07-19-2009, 07:13 AM
yes
Plan accordingly!
Old 07-19-2009, 09:35 AM
Most systems will not let you draw out of both tanks. Your fuel pump will draw out of the tank of least resistance and then suck it dry. Then you think something is wrong and look for the problem...which is you are out of gas on one tank.
Ask me how I know
FWIW:
# Three-Way Valves connect two permanent tanks to a single motor.
# Four-Way Valves connect three permanent tanks to a single motor.
Old 07-19-2009, 01:37 PM
If you have the old fiberglass tanks with gravity drain (NOT siphon drain) fuel feeds, you can pull off both tanks at once. I had twin tanks like these on an a 24' T-Craft. The tanks drained out of the bottom through a filter to the valve.
These tanks will also self-equalize fuel amounts.
