Old 07-29-2009, 03:48 PM
shrimper1234 shrimper1234 is offline
Default A&J Bracket?
Anyone used an A&J Flotation Bracket on a 23' seacraft for a single engine? Again, the cost is nearly half that of an armstrong bracket of the same size.
Old 07-29-2009, 04:05 PM
Default Re: A&J Bracket?
or should i say a bracket built by A&J Marine in Miami.
Old 07-29-2009, 04:50 PM
KenB KenB is offline
Um... didn't someone just start a similar thread called "D&D Brackets"?
http://www.classicseacraft.com/forum...b=5&o=&fpart=1
The consensus seems to be that a fiberglass bracket from Hermco is the way to go.
Old 07-29-2009, 05:18 PM
Shrimper - I'm a cheap bastard too . . . there's nothing wrong with buying an aluminum bracket. I'm so cheap . . . I decided to build my own . . . even though I probably didn't save any money doing that. If you want to save some dough . . . why not look for a good used bracket? The reality is that they are just a few aluminum plates cut to size and welded . . . no rocket science. The profit has to cover the overhead . . . Armstrong and Stainless have more overhead costs than Joe Blow welder, which is why they have to charge more . . . I don't think you'll see too much difference in quality. Don't get Analysis Paralysis over the bracket decision . . . Just work a little harded and save your $$$.
Old 07-31-2009, 11:08 AM
Keyscruz Keyscruz is offline
My bracket was built by A&J in Miami. It is on an 18SF and has a 36" wide flotation chamber and has a set back of 22". It was made to my specs. It is nicely made and finished. My first choice was a Hermco but it was more than twice the $$. The aluminum will require more maintenance than a Hermco.
Old 08-03-2009, 08:06 PM
lost2a6 lost2a6 is offline
I had one on my sceptre. It was built to my specs. It seemed to be built good however the powder coating on it sucked.
Steve B
Old 08-04-2009, 09:15 PM
3rdday 3rdday is offline
On my 21 which is really a 22 I used one and I like it, you know the 23 was splashed off this 21,cut down & modified.
Old 08-05-2009, 09:38 AM
???? Explain please. I thought when I last pulled the tape it was 21 feet exactly. Or are you now counting the bracket.
