Old 08-09-2009, 10:41 PM
rockdoc rockdoc is offline
Default best way to cut?
I'm replacing the 500 and 800 gph Rule bilge pumps in the Sceptre with a 1500 and 2000, so I'm going from 5/8" to 1 1/8" hose and thru hulls. What's the best way to enlarge the holes for the (above water line) through hulls?
Steve
Old 08-09-2009, 10:56 PM
mustang10 mustang10 is offline
Default Re: best way to cut?
Nest your hole saw bits. Put the smaller dia. bit (orignal hole size) inside the new larger one. The smaller one will act as a guide for the new hole. Hope this makes sense.
Old 08-09-2009, 11:33 PM
JOEKEN JOEKEN is offline
That is an awesome idea. I would of been stupid and just tried to hold it steady with the larger holesaw only. Thanks for the tip!
Old 08-10-2009, 11:39 AM
I used a block of wood behind the existing hole to guide the pilot bit. It worked great.
