Old 04-13-2010, 04:44 PM
SBD SBD is offline
Default Best way to seal bracket holes thru transom?
I just dry fit a new bracket and plan on taking it back off to seal/sleeve all of the mounting holes. What do you guys think is the best technique and/or material for doing this job?
Thanks!!!
Old 04-13-2010, 08:43 PM
fdheld34 fdheld34 is offline
Default Re: Best way to seal bracket holes thru transom?
Where's Don when you need him
I believe 5200 for sealing holes and mounting bracket...again I believe..or was it 4200?!
-Fred
Old 04-13-2010, 09:02 PM
stoney stoney is offline
I believe this is the best method.
http://bertram31.com/proj/tips/sleeving.htm
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 04-13-2010, 10:23 PM
abl1111 abl1111 is offline
- Oversize drill needed holes, fill with epoxy.
- Drill through center of the filled, cured epoxy hole w/ correct size bit for bolt(s).
- Install/seal with polysulfide.
- Don't look back.
Good luck...
