Old 08-08-2010, 03:45 PM
2182 2182 is offline
Default thru hull in side, how thick?
changed baitwell system around recently for better ride. got a portable 30 gallon tank now riding in front of the console. i want to drill a thru hull for drainage through the side of the hull. boat is a 1985 18 ft cc. i am wondering how thick the sides are. hole will be above waterline towards the front of the console. i am not a seacraft purist. i bought the boat for the ride and have been making modifications ever since. just want to "call before i dig".
Old 08-08-2010, 09:01 PM
Default Re: thru hull in side, how thick?
They should be the same diameter as your new 30 gallon tank drain hole is. Don’t reduce it. You should have 3 holes one to fill the tank one for overflow and one for end of day draining.
FellowShip
Just for the Grins
Old 08-08-2010, 11:02 PM
baitwell has all the holes already, i want to cut a hole in the side of the boat for easy drainage and am wondering how thick the actual hull is under the gunnel.
Old 08-09-2010, 10:17 AM
On my 23' it's .385" thick. This is six inches down from the rub rail when I installed a second/backup bilge pump.
Old 08-09-2010, 09:16 PM
im assuming you came up through the bilge? im talking about going all the way through both walls and whatever is in between. cannot get a hose up from the bilge that far. tank is blocking it and i dont want to run through the console, which is filled w/ batteries etc.
Old 08-10-2010, 08:28 AM
Oh.....you meant the through the hull and the inner liner of the boat. I'm thinking around 1" to 1 1/2", no more.
