Old 10-05-2010, 03:53 PM
shine shine is offline
Moderator
Default Trailer question for 23CC, need a measurement pls
I am locating a trailer to use to pick up a 23CC. I could really use a couple quick measurements from someone who has a 23CC. I want to see if I need to modify trailer before picking up boat.
Vertical distance from top of rollers to top of bunks, and distance of bunks from the center line of trailer (or distance between the two bunks will work too)
Thanks!
Old 10-06-2010, 08:07 AM
Default Re: Trailer question for 23CC, need a measurement pls
I can get it this afternoon. You want the rollers between the bunks??
Old 10-06-2010, 11:06 AM
Moderator
yes please, the vertical disstance from roller (on the ceterline) to the top of bunks.
Also, distance between bunk (inside side of bunk to inside side of bunk)
I can use those to determine if the bunks on the trailer need to be raised before I go pick up the 23.
THANK YOU !!
Old 10-06-2010, 04:00 PM
Bunks ~ 32 1/2" inside to inside
keel rollers are ~ 9" below top of bunks in center of roller. My bunk tops are beveled to fit hull taper.
Old 10-06-2010, 05:26 PM
Moderator
THANK YOU !!!!
