Old 11-13-2010, 05:37 PM
geesea geesea is offline
Default salt water pickup-inboard
I would like to change my original saltwater pickup thru-hull in my 23 seacraft savage. I do not know how it is fastened through the hull. I do not see a threaded section or nut on this thru-hull. Could it be just bonded?
Old 11-13-2010, 07:22 PM
BigLew BigLew is offline
Default Re: salt water pickup-inboard
It may be thread directly into a thru-hull seacock and thus you may not see the threads. You did not mention if there is, infact, a seacock at the trhu-hull point. Either way, it is movable with the proper repair of the old hole(s) in the hull. (In addition to the main thru-hull hole there will be generally three hulls into the hull for screws to prevent the seacock from twisting on the thru-hull portion of the device.)
Just my two cents. Good Luck.
Plan accordingly!
Old 11-13-2010, 09:36 PM
thanks for the reply. Yes there is a seacock with a scoop on the outside of hull. It has three small screws. I do not see any screws on the inside of hull?? Are you saying that the sea cock should be threaded in to the scoop pickup on the outside of the hull?
Old 11-14-2010, 10:51 AM
I sent you a private message.
Plan accordingly!
