Old 05-27-2011, 09:24 AM
SBD SBD is offline
Default Wiring Diagram
Do you guys know of a source for for a good wiring diagram for a basic one motor/two battery set up?
Thanks!!!
Old 05-27-2011, 09:43 AM
bobbert bobbert is offline
Default Re: Wiring Diagram
Go to the PERKO web site. Has diagrams for any comniation of batteries and engines.
Good luck
Bob
Old 05-27-2011, 11:24 AM
SeaPlusPlus SeaPlusPlus is offline
I can offer the one I did for my boat. I designed this one up and installed it on my SF20. Has worked great for a year now.
Click on the image for a larger more readable size. Can't promise it will work 100% for you but probably a good start.
Old 05-27-2011, 11:37 AM
SBD SBD is offline
Thanks a ton, that is super helpful. I see you used a fuse block instead of a breaker panel. What made you go that way? I have been wondering which way to go.
Seems like with a fuse block or fused switch panel you can get a better match for amps than with a breaker setup.
Old 05-27-2011, 12:08 PM
Yeah that's why I went that way, each item can be fused to its proper amperage, was cheaper as well. I keep a small tackle box on board with at least (2) replacement fuses for each size fuse on the boat (blade and tube). Knock on wood but haven't blown one yet.
