Old 10-11-2011, 11:06 PM
basswacker basswacker is offline
Default how to winterize OB
i have a 1989 Johnson VRO. What do I have to do to get it ready for winter. the tank is half full. i plan on letting the engine run out.
Thanks
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
Old 10-12-2011, 06:40 AM
pelican pelican is offline
letting an engine run out of fuel,before allowing it to sit for an extended period of time,is never a good idea.
a better approach is to run the engine on a "winterize mix",me,i use 5g of fuel,a gallon of oil and a shot of stabil - i run the engine to temp - perform a compression test,service the gear case,pull the wheel,lube all points,then,disconnect the fuel to the engine-connect my mix tank,and run the engine again,with the salt a way flush connected.allow the engine to run till it begins to smoke,run it to temp again,then increase the idle spped,and kill it with the primer - "choke"...
this,puts a fuel/oil mix in the carbs - fuel evaporates,oil doesn't,the inside of the carbs are sealed in a lite coating of 2 stroke oil - eliminating all potential problems...
Old 10-12-2011, 11:12 AM
should i fill the tank and add stable or is half filled with stable fine if i have a water/fuel separator?
Mmfishinglures.com
1976 23' Scepter
Old 10-12-2011, 06:42 PM
riverrat riverrat is offline
Default fogging oil
i agree with bushwacker, I run the engine till it warms up and start spraying fogging oil in the carbs till the engine stalls out..then i pull the plugs and spray some more fogging oil on top of the pistons and hand crank the flywheel over one time..never had a stuck piston when i uncovered the boat in the spring, just looks like an airshow is in town when i fire up the engine to clear out the fogging oil. i also use engine cleaner and get as much salt off then spray some cpc on the engine.
Old 10-12-2011, 08:15 PM
Hey cuz, what, no cheaters or maybe it was Mr. Jim Beam..
It's BassSmacker not bushmaster.....
See ya bro... Keep the planes in the air..
Old 10-13-2011, 02:57 AM
Wink senior moment
thanks cuz, i had a senior moment and miss placed my cheaters when i was typing...
