Old 10-19-2011, 02:58 PM
TooFly TooFly is offline
Default Thru-hull Ducer Rigging
There's an existing Garmin thru-hull ducer cable in the boat now. I wanted to use it to pull the new thru-hull ducer cable forward to the console. But the old cable isn't budging. So do I need to pull the console off and fuel tank out to run the new ducer cable from the bottom of the hull to the console? Seriously?
My boat is a 1978 20' CC, BTW.
Thanks,
Paul
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
Old 10-19-2011, 05:06 PM
htillman htillman is offline
I took the metal cable from an old shift cable and was able to snack it under the floor to the back of the boat. If you can find a stiff metal piece of wire get someone to get in the back of the boat while you thread the cable from under the console, have the person in back listen for the cable and he may be able to grab it. It worked for me two times now.
ET
Old 10-19-2011, 05:25 PM
Wildman Wildman is offline
Old control cables' sheath work great with the metal 'cable' part removed. Very flexible and can be bent to help guide them into tough spots.
Old 10-19-2011, 05:42 PM
Here ya go, a cheap solution.....and remember when you pull steering cables, wire, etc. always pull another pull rope with it and then leave in place for the next time.
http://www.harborfreight.com/50-ft-fish-tape-38156.html
Old 10-20-2011, 01:14 AM
let me emphasize the ALWAYS!!!!!! you can use some dish soap or something similar to lube the wire/cable your pulling. it will help. also try to make your knots or wire to rope connections as streamlined as possible and wrap with electric tape and the soap. will pull right thru
Old 10-20-2011, 05:50 AM
riverrat riverrat is offline
Talking para-chute cord
i got my hands on some old discarded para-chute cord at a local airport and use it to snake wires and i put a thin coat of grease on the chut-cord,works great when pulling cables thru hard areas..
Old 10-23-2011, 08:01 PM
Yup. I dug mine out of the garage and it worked like a charm. It took no longer than five minutes to do myself. Using it to snake cables behind the walls of our 85 year old house is another matter, though. I grabbed some cord to leave behind for the future, too.
Thanks for the replies, guys. I appreciate them.
