Old 01-01-2012, 09:01 PM
GodsReel GodsReel is offline
Default winterize or run every month?
Any opinions on winterizing or just running every month , i am so worried about the whole ethanol phase seperation problem, I am thinking of just running my boat often enough to keep it fresh. The way the winter is going here in va , i think the striped bass my be here all winter so i will just fish every few weeks ???
Old 01-01-2012, 10:00 PM
pelican pelican is offline
for what it's worth:
i winterize and store between 40 - 50 boats every season - i have NEVER had a problem with fuel in the spring...there's alot of misinformation and old wives tales concerning fuel.since ethanol was introduced into the fuel,i've had 3 problems that were the direct result of fuel - all 3 boats got fuel from the same source - a fuel dock...since that,not another problem !
phase seperation comes from water in the fuel - if you've experienced water in the fuel previous - you need to find that source - leaking deck plate ? incorrect vent positioning ? leak in the tank ? - find the source,cure the problem...
what i do: add stabil to treat the fuel and that's it...i endorse no fuel additives - startron,sea foam,whatever - none of my clients use it...
running the boat every so often will really do nothing - if you're implying you're gonna hook up the hose to the engine and fire it up,allow it to run for a while and shit it down.the engine never really "works",it's not under load,it's simply running...
if you're implying you're gonna use the boat,that's different - the engine's under load and working - that's good...
fogging an engine is reccomended,if the engine's going to sit for an extended period of time...
Old 01-02-2012, 12:03 AM
Thanks pelican, i would at the least go for a boat ride , hopefully go trolling for a few hours or so. that would entail a fifteen minute or more run to where the bite might be. This year i am in dry storage and it will be easy to launch and run. thanks for the input.
Old 01-02-2012, 08:44 AM
Hey, Godsreel. For what it's worth, I run mid-grade exclusively in my Zuki and it will sit for about 2-3 months each year over the winter. I keep it full, add some seafoam and have not had a problem yet. Same thing last year.
Old 01-02-2012, 07:53 PM
76Red18 76Red18 is offline
Smile
Twice a month minimum in Florida. Grouper seasons still open and trout opened Sunday..
J. M. Hendrix
