Old 05-17-2012, 10:02 PM
sidelock sidelock is offline
Default screw hole repair
I am going to remove/eliminate the bow rail & need advice on how to deal with patching up the exposed screw holes.
Old 05-18-2012, 07:19 AM
mnwnvc mnwnvc is offline
I use a counter sink on each hole to make it taper from wide on top to narrow on the bottom. Place a piece of blue painters tape over the hole on the underside. Mix thickened epoxy and fill hole. Cover with a piece of plastic wrap and smooth with a thin putty knife and allow to cure. Requires only a light sanding and maybe a little fill in places.
Old 05-26-2012, 09:42 AM
Lordwrench Lordwrench is offline
Is six10 suitable for filling holes?
Old 05-26-2012, 11:02 AM
Yes, very good for filling holes. But keep in mind the tube is only half the typical content of a regular caulk tube.
Old 05-26-2012, 01:31 PM
i like the plastic wrap idea. i usually use a razor blade to smooth it while it still wet.
