Old 06-09-2012, 03:54 PM
ChadsSeaCraft ChadsSeaCraft is offline
Default HDS7 transducer
Which transducer works with an HDS7 on a 1978 23ft CC? I belive it has a 20 degree deadrise.
Thanks,
Mike
Old 06-09-2012, 04:51 PM
CATmech945 CATmech945 is offline
I have the HDS 7 and the transducer came with it. The transom mount ducer works well. Yours didn't come with one?
Old 06-09-2012, 05:01 PM
No, I just picked up a 1978 23' from someone who ran out of money while redoing the boat and one did not come with the boat.
Old 06-09-2012, 05:18 PM
i have an airmar on my hds-8.
Old 06-09-2012, 05:24 PM
Do you know the model number ?
Old 06-09-2012, 05:28 PM
I don't think it matters what transducer you use as long as the connections at the unit match up and you don't have to mount it on the transom. The installation guide showed a way to epoxy it to the center of the hull on the inside. I'm pretty sure you can find one on the lowrance web page though. I just looked it up and the units can be purchased with or without so I'm sure you can get one separately. If you're close to a west marine, maybe try checking there. http://lr.factoryoutletstore.com/cat...ansducers.html Try that link. They have the transom mount for 80 bucks. Product # 106-71
Old 06-09-2012, 06:02 PM
Either an Airmar B60 or a B164 20 degree tilted element is the way to go.
Old 06-09-2012, 08:03 PM
drilling the hole to mount that thing hurts. i didnt want to do it so i walked away as a friend drilled it.
you can take that transom mount one and glue it down in the hull bottom. it does work. thats how i had it before i got the airmar. i used clear silicone so i could remo if needed. the temp is going to be off.
Old 06-09-2012, 08:12 PM
I know what you mean about dilling that big hole....Im looking at the transom mount one also.
Old 06-10-2012, 07:13 AM
the install itself was actually quite easy after the hole was drilled. im going out today and i still have the transom mount glued down. ill run both and report back on the difference.
