Old 06-13-2012, 04:21 AM
Clarky Clarky is offline
Default Any help or "direction" would be GREATLY appreciated!
I'm in the middle of doing some cosmetic repairs.
Re-installing existing rub rail: This had been done before, and the guy moved the screws a bit to one side. For the repair, I'm thinking that instead of using screws, I'll use 1.25 inch bolts and teflon nuts... good idea? Also, should I fill the "old" holes with 5200 or just silicone?
Old 06-13-2012, 07:02 AM
BigLew BigLew is offline
Clarky,
I just went on the Taco Marine website.
http://www.tacomarine.com/
On there, they have a couple of rub rail installation manuals which can be downloaded. One for flexible styles and one for rigid styles. You didn't say which you are dealing with. I'd suggest you check them both out before you turn on a drill or anything else regarding your project. Good Luck.
Plan accordingly!
Old 06-13-2012, 07:15 AM
Clarky,
This will help you find it faster.
http://tacomarine.com/cgi-bin/ccp51/...f=&pg=ste_inst
Plan accordingly!
Old 06-13-2012, 07:49 AM
I reused mine after a resto. and thru-bolted as well. 5200, nyloc nuts, and fender washers. No affiliation here but Warren Fasteners has way better pricing compared to West or others.
Old 06-13-2012, 07:54 AM
I worked at WM and learned some of the "profit margins" of some of the things they carried. Fasteners, bolts, screws, nuts, etc. probably had the highest margins in the store.
Plan accordingly!
