Old 06-29-2012, 03:11 PM
6buoys 6buoys is offline
Default omc spit fire
working on omc spitfire .runs up to 3200 rpm and stalls out . told module was bad .to put new mallory in .did that same result only it dies at all diffrent rpms over 3200 any ideas or help is welkome
Old 06-30-2012, 04:01 PM
not sure what module your talking about nor what year or size the engines is - that would help
Old 06-30-2012, 11:45 PM
The "Spitfire" is a high-voltage ignition system put on OMC hi-performance Cobra sterndrive motors. They were EEPROM controlled computer ignitions and coils that failed spectacularly, repeatedly.
There are several aftermarket replacement systems that can be used to replace the Spitfire with a standard distributor type.
Old 07-06-2012, 10:45 AM
3rdday 3rdday is offline
Default Spitfire
I had an Evinrude spitfire 150 outboard, it ran fantastic. Very dependable and lots of power.
It was on a Full Transom Bracketed Chris Craft Scorpion Cuddy with Hardtop. I think it was also marketed as a Johnson Interceptor.
